It is currently Sun Jul 20, 2025 4:34 pm
PostPosted: Sat Aug 11, 2012 9:40 am
First name: D
Last Name: S
I mixed a Neovin high output Tele neck pickup with a Power rail bridge pickup.
They are wired in parallel through a selector switch. Both center taps go to a push pull pot. The Tele pickup sounds muffled, selecting both gives a thin shrieking high end, and bridge only sounds like a humbucker bridge should.
I am using a Gibson style bridge with a 12" radius. The Tele pickup pole pieces are past the top and last string, so these two strings are muffled. Also, the radius of the Tele pickup is smaller than 12"
I have decided to risk ruining my finished guitar and route the neck pickup cavity to fit a humbucker.
I have a normal humbucker pair I would like to use.
Before I proceed, would it be worth trying a different wiring setup?
Basically, I was trying for a Fender and Gibson sound on the same guitar.
I suspect some of my problem may be using the high impedance overwound pickups.
Thanks for suggestions,
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Sun Aug 12, 2012 4:21 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
I would rewire it very simply,
without coil taps,
and maybe just from the pickups to an output jack,
and hear how it sounds.
I have a problem guitar that I tried rewiring differently 6 times,
and it still ain't right.
I'm guessing it's because one pup is a high output humbucker,
and the other is a p-90 type.
Seems like it should work though.
I went with 2 vol pots,
and 1 tone, no switch.
Maybe that's why it doesn't work properly.
It does sound good though.
The tone pot acts weird.
Good luck!
PostPosted: Sun Aug 12, 2012 8:14 pm
First name: D
Last Name: S
without coil taps,
Good luck!
Thanks Alan,
I measured the tele pickup at 7.6k ohms and the bridge at 16k ohms.
Quite a mis-match. I'm going to try swapping the bridge PU with a normal humbucker.
I had a thought of using a busted or cheap guitar as a test bench. I could route a large area to temporarily place pickups, and buld a universal control panel, maybe with terminal blocks to allow quick wiring test changes as well as pickup combos. It's a real pain to replace and rewire a pickup on a finished guitar.
Dan
wah
Wah-wah-wah-wah
Wah
cron
